4l60e Rebuild Thread
I just don't see how the EPC can significantly reduce the Reverse pressure (below 75psi) unless something is really ****-eyed in the boost valve area.
I know the Reverse feed pressurizes between the ***** of the boost valve, but don't see how that moves the boost valve to increase pressure. However it must work because Reverse normally has much higher pressure than Park or Drive. The PCM cannot distinguish Reverse from Drive and therefore the PCM/EPC cannot be increasing the line pressure in Reverse.
Guess we'll see the result when the OP installs the Sonnax boost valve.
You are diagnosing problems with professionally built transmissions.
I'm often diagnosing problems due to missing/wrong parts or wrong assembly by amateur builders.
Example: an OEM .471" boost valve has a diameter of .471" on the small land, and a diameter of .505" on the larger land. The size of the portion between the spools is .275". If you figure the surface area of all of those, you can figure out how much force a valve will generate.
Small land surface area: .1742 sq.in.
Large Land surface area: .2002 sq.in.
Portion between the lands: .0593 sq. in.
So, the small land has an acting surface area of .1149 sq.in (.1742 - .0593 = .1149 sq.in.). And the large land has an acting surface area of .1409 sq.in (.2002 - .0593 = .1409 sq. in.). So, the difference, and thus the surface area that will actually generate force to act on the pressure regulator valve is only .026 sq.in. (.2002 - .1742 = .026 sq.in.). That is not very much area at all, which is why there is not much boost from the R/I pressure acting on the boost valve.
100 psi of pressure on the .471" land (EPC oil) will produce 17.42 lbs of force on the end of the PR valve. That same 100 psi of pressure between the lands of the boost valve (R/I oil) will only generate 2.6 lbs of force on the end of the PR valve.
EPC is the main source of line pressure boost in both forward and reverse...
Check out post #54, OP Says, "I was able to get under the car to check servo play tonight and it was definitely close to 1/4". I put 1 gold shim in and the trans still slips. I'll have to order some when I order the pressure gauge."
The servo pin should have around an 1/8" of movement from what I have read. I hope someone can chime in and concur or refute this.
The gold shim in the Transgo kit is an attempt to tighten up the servo clearance on a worn band to help the 2-3 shift. While it does decrease servo travel, it is a band-aid for a worn out band.
I have a completely disassembled 4L60E in the basement for such research/learning and to answer assembly questions.
EDIT: Just took the car out while commanding full line pressure...clutches are toast. Only have 1st gear and a little bit in 4th.
Been there, done that...
The Band looks fine, The 3-4 clutches will burn down first. You needed to find the reason for no Pressure Rise before pulling the unit. Installing new frictions will NOT fix anything.
A new AC Delco reverse input drum is about $80-90. I paid $70 shipped a year ago but for some reason all 4l60e parts have dramatically jumped in prices since then, including solenoids and the MPS.
And here is a picture of all of where I stopped for the night:
In the morning I plan on testing the input drum seals and then assembling all of the clutches back into the case. Hopefully by tomorrow night the transmission will be mostly put back together and I can spend Sunday starting to put it back in the car.
Pictures from todays progress:
