4l60e Rebuild Thread
I bought hundreds of them from a Auction that was selling out a Trans shop's inventory.
Look at the end of the Accumulator Valve Bushing, The "Horse-Shoe" should face UP with the Valve Body installed in the car.
Then look at the bottom of the Valve Body where indicated, You should see JUST the Spool, Not a LAND. If you see a Land half exposed in the window....The Accumulator Valve is in backwards.
Is this the same thing you are talking about above?
Pretty sure I found my problem. I took apart all of the valves and found that the 32 downshift valve and spring were installed backwards (#389 and 390). This would make sense that the issue was in both rebuilds since I didn't touch any of the shift valves in the 2nd rebuild.
Hard to see, but this is how it was assembled when I took it out:
The last bolt caught the edge of hole in the valve body side of the separator gasket so I need to pull the separator plate and replace the gaskets. The valve body is fully inspected and I plan on tackling the not so fun part of trying to work on my back and get everything installed correctly tomorrow.
Sorry that I should have remembered another post where 1->2 upshift problems were caused by problems in the 3-2 downshift circuit.
Fingers crossed.
. Can't wait to get back to the track and shave a couple of tenths off my ET now. The Best V8 Stories One Small Block at Time
