Builders - Differences in Rebuild kits 2003 to 2004 4L60e
Old Oct 26, 2015 | 05:13 AM
Lost_in_calgary's Avatar
Default Builders - Differences in Rebuild kits 2003 to 2004 4L60e
Ok, so I tried searching this but did not find an answer.
I was looking to purchase a rebuild kit for a 4L60e transmission. I see there is a kit for 1998-2003 years and a kit for 2004+ years.
My car is a 2004 but it was build in 2003, so which kit do I need? Is there an easy way to tell the difference between 2003 and 2004 transmissions? IE prior to removal.
BIG QUESTION:
What is the difference between the two kits?
Old Oct 26, 2015 | 09:13 AM
mrvedit's Avatar
Moderator
Perhaps one of the pro builders can tell you the difference, but it will be incredibly small and insignificant.
I strongly suggest everyone using this forum always use (or ask their stock builder to use) a 4L65E rebuild kit. The only different is that it has 7 frictions for the 3/4 clutch instead of 6. Sure it cost $10 more, but that 3/4 clutch is the most common failure reported here. So get a 2004 4L65E kit.
Also add the Sonnax 4l60-LB1 boost valve ($30). A new separator plate is also highly recommended - get the Transgo 46-PLT-96 ($20) and drill it according to its directions for a V8. You might want to drill the 3rd feed hole (also called 2-3 shift hole) a bit bigger to .093.
We have lots of threads now on how to rebuild your own trans and the success rate is going up dramatically. Here are a few recent/current ones:
https://ls1tech.com/forums/automatic...60e-build.html
https://ls1tech.com/forums/automatic...arts-list.html
Good luck.
Old Oct 26, 2015 | 09:46 AM
unit's Avatar
How about the Torlon ***** I keep reading about. Are they a better, more reliable substitute for the steel ***** in the 4L60E?
Old Oct 26, 2015 | 12:11 PM
antoine's Avatar
They will not damage the separator plate like a steel ***** will
Old Oct 26, 2015 | 12:18 PM
mrvedit's Avatar
Moderator
While the Torlon ***** are better, a new separator plate will last 100,000 miles even with the steel *****. Torlon ***** are only a few dollars.
As I understand Ford uses Torlon ***** extensively.
Old Oct 26, 2015 | 05:26 PM
clinebarger's Avatar
Starting in late '04, The Pump O-ring was eliminated & Replaced with a "Press-In" Metal clad seal, Most '04 models used the O-ring, If your trans was built in '03....Get the earlier kit.
Old Oct 26, 2015 | 06:34 PM
unit's Avatar
Thanks guys. I'll go with the earlier design then.
Old Oct 26, 2015 | 10:29 PM
mrvedit's Avatar
Moderator
Thank you for the correction and update. I keep forgetting that some of the later pre-ISS pumps have the seal pressed into the case.
You should be able to find a 2003 4L65E rebuild kit with the better 7 friction 3/4 clutch. If you have to get a 2004+ kit, any local trans shop should have spares of the pump o-ring. Or PM me your address and I will send you one.
Old Oct 27, 2015 | 04:59 AM
Thanks for the clarification on the difference between the 2 kits.
Old Oct 29, 2015 | 11:05 PM
Predator T/A's Avatar
you will also find in the late model kits they will not have lip seals for the input pistons in the kits and will have valve body gaskets for 200-2004 and 2005 and up
