would a bad mass airflow sensor affect shifting negatively?
If the sensor is under reporting shifts can be soggy and even slip. With the MAF unplugged I believe the PCM is supposed to increase line pressure as a fail safe.
i changed mine 2 times, eventually tossed the KN in the storage room and put a paper air filter in,
my car has never shifted better
But I hadn't be driven in a couple years. The power steering pulley bearing wore
down and I didn't know until it failed and threw the belt,
by this time the oully had been riding crooked on the shaft
and wore a hole in the reservoir. Which forced me to buy a new set up
and alternator cause the other one got soaked with fluid and failed.
Now since I took the intake off to replace all this I've been getting
a maf code and intake temp code after cleaning both and
having the code cleared 3 times. I can unplug the maf and notice
zero change in the way the car runs. When I'm sitting parked
the car has a wobble feeling, and when I put it in drive with my foot
on the brake it get a little worse. When I let off the brake it gets a little better
but still noticble. It didn't do any of this before it started throwing
codes. Can anyone help me with this?
If you use an oiled air filter, make sure you clean your MAF periodically to prevent this condition from returning. I'm finally gonna switch to an oiled filter soon, so I will make sure I have a can of MAF cleaner handy.
-start a new thread
-start the thread with the year/make/model of vehicle
-list any history/backstory in a well broken down, easy to read format...not 619 words of run on
-note any diagnostic you have done/tried. Codes, line pressures, etc
bringing up a 5 year old thread isn't the best way to get the best help for your particular situation
