Performabuilt Level 2 4L60e Testimonials
Old Feb 6, 2016 | 09:10 PM
jhshnh's Avatar
Originally Posted by LS64
Looks like Santa Clause came early for some! Once you guys get a few miles put on the trans please come back and let us know what you think
After lots of overtime and no time off, I was finally able to get my level 2 and fti 4000 hard hit in.
I'm still breaking it in, so no hits yet. Rain+et streets+4000 stall don't go well together. I will say I followed the startup directions on the Performabuilt site and it went flawlessly. The trans drives similar to stock driving normally. The stall is loose but not bad at all for a 4000 hard hit. Certainly streetable for a car that's a weekend toy. You know it's there, but it locks up and everything. I also had my tuner return the line pressure to stock as recommended by Frank.
I had to call a couple of times with questions and each phone call was returned and I got excellent customer service. Those guys are true professionals and I'd buy from them again.
So, as soon as it's broke in I'll set my shift points, and hit the track! Hopefully next weekend.
Old Feb 8, 2016 | 08:04 PM
jhshnh's Avatar
Update: I've driven normally for 85 miles, let is cool all the way down, just like the directions say.
Then it was time for the fun. The stall hits hard at 4000 (it is a hard hit lol) and the et streets that spun very little with my stock stall now spin pretty hard!
The transmission shifts are hard and fast under wot. Had to adjust the Rev limiter for the 2-3 shift because it would hit the Rev limiter before shifting. One quick call to Frank and problem solved.
Converter locks up under normal driving and feels like a stock converter/trans going down the highway.
I also installed a bmr chromoly torque arm and a bmr torque arm relocation crossmember. I took my time and got a pinion angle of -3 degrees. Car is much stiffer now with this setup. I don't notice the torque arm road noise like I've read about. The car has very little flex, but no annoying road clunks.
I'd recommend Performabuilt and fti to anyone. The customer service is first class, I can't say enough good about those guys.
As soon as my track opens I'll post times.
Old Feb 11, 2016 | 03:50 PM
ironmikektm525's Avatar
I agree 100% on the customer service from performabuilt! Frank/Alan are great guys and are there for you!!!
Old Feb 13, 2016 | 02:24 AM
Ws6Dnero's Avatar
I have a level 2 performabuilt. Been rebuilt about 3 times so far in the last 3 years from the 3-4 constantly going out. Had it rebuilt locally the last time by a reputable builder. Drove it for 2 days before my motor popped but as far as normal driving goes, its shift firm but not too noticeable. WOT its another animal. I always wondered how they can offer the trans for quite a bit less than others and rate it for the hp that they do but anywho some people have had good luck, some didnt. When i get this car crunk this week and if this trans can hold the power for a while without dying i may shop again for a built 4l70e for my trailblazer ss.
Old Feb 13, 2016 | 05:57 AM
Ws6dnero. How much hp you making? What stall/transcooler you running?
Old Feb 13, 2016 | 03:00 PM
Ws6Dnero's Avatar
Haven't had my new setup on the dyno yet. Just put the new motor in. Forged 370/D1SC with 3.40 pulley. PTC 3500 converter. B&M 70274 cooler and braided lines. Aiming for 700 plus.
Old Feb 13, 2016 | 05:42 PM
Ws6Dnero's Avatar
But before this setup, i had a head/cam lq4 and a yank 3600ss with a different brand cooler.
Old Feb 15, 2016 | 07:39 PM
Ok just wondering. I'm just boltons so my stage 1 should be fine. Can't wait to break in the yank and feel the difference. Never driven a stalled car. My pcm from frost comes tomorrow. Not that I can drive it(upstate NY)
Old Feb 15, 2016 | 11:24 PM
mrvedit's Avatar
Moderator
I would still recommend the Stage 2 as you get ungraded parts for only a little bit more; basically the cost of the parts.
Old Feb 16, 2016 | 11:20 PM
Ws6Dnero's Avatar
Has any of the parts used to build the level 2 performabuilt previously been updated?
Old Feb 17, 2016 | 08:11 AM
performabuilt's Avatar
LS1Tech Sponsor
Over the years there have been several updates and changes to improve the level 2 both in the valve body modifications and clutches used . servos we make all reasonable upgrades as we find something we think will be better or sometimes one change makes another change a better idea , But yes we are always looking for better ways to make all our units stronger.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Feb 17, 2016 | 11:25 PM
  #32
Ws6Dnero's Avatar
I need a strong trans for my tbss
Old Feb 18, 2016 | 08:31 AM
  #33
LS1Tech Sponsor
Give us a call to discuss 5705783522 or our 888 number in signature .
__________________
Call 888-744-6542
Old Feb 21, 2016 | 09:16 AM
  #34
98z28jorge's Avatar
I've gone 10.00@135 on a head cam 6.0 on a 200 shot on my performabuilt stage 2 wish it had a trans brake tho best 60ft so far been 1.4
Old Feb 21, 2016 | 08:09 PM
  #35
LS1Tech Sponsor
We can add a brake to the trans but will cost around 1000 aprox give alan a call to discuss.
__________________
Call 888-744-6542
Old Feb 28, 2016 | 06:49 PM
  #36
jhshnh's Avatar
With my level 2 and fti 4000 hard hit I shaved .6 second down to a 12.29 with 1.7 60'. Transmission runs flawless and overdrive kicks in at 55 cruising the hwy. Not bad for a car with kooks headers, exhaust, slp lid, tune, and stock 2.73 gears.
Old Jun 28, 2018 | 06:59 PM
  #37
Joser's Avatar
Default Performabuilt level 3 4l60e
I've been using performabuilt level3 4l60e with trans brake never had a problem with it over 4 years driven it everywhere and I'm spraying 200 shot of nitrous heads cam ls1...but I'm having a hard time rite now what to do I sold my ls1 and I'm building a 5.3 stroker383 ls going twin turbo 76s and my goal is 1300rwhp and i spoke with performabuilt and he said they have the new black label 4l60e that's rated for 1400rwhp and I don't know if its really gonna hold up..I was thinking about going powerglide..tell me what you guys think?
Old Jun 29, 2018 | 11:00 AM
  #38
tug686spd's Avatar
Id say your current trans has already paid for itself so what do you have to lose trying it. I'm sure your not going straight to 1000+who so you'll know when it's starting to slip. I'm sure you know they are good guys to deal with and they've got a decent price on the refresh along with being able to upgrade if you ask. Down time and shipping might hurt you some but I'm lucky and I'm about 45min away from them.
Old Jun 29, 2018 | 11:28 AM
  #39
Joser's Avatar
yea there awesome people and spoke with them told them what I'm planning on my new set up and hp goals he sounded really confident that it will hold 1300rwhp..I just never see people running 4l60e 1000+ rwhp I just wanted to see you guys opinions on this topic...thanks for your opinion
