4l60e no forward or reverse new trans and torque converter
Old Dec 15, 2015 | 08:08 AM
performabuilt's Avatar
LS1Tech Sponsor
The fact you have a grinding noise when placing in park tells you the output shaft is turning. I would have to say either the transfer case if bad or the collar where the shaft goes in is stripped the only other possibility I can think of is the rear planet splines are stripped out. Its not an electrical issue
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Dec 15, 2015 | 01:55 PM
94 5.7 k1500's Avatar
Something in the t case broke. Output shaft spins freely no matter what gear the trans or t case is in. And it was full of fluid. I filled it when I installed it. Just drained it but saw no metal. Maybe a snap ring or fork in the t case broke? Hoping I have parts from my old one to make one of them work..
