04 trailblazer 4l60e pump
A total pump failure is usually caused by a broken pump rotor. GM made some improvements to the pump, but none after '04 that I know of.
I suspect many pump failure are due to a previous converter swap that was not done as carefully as it should be.
Sure, there are pump rotor failures, but not very common.
If you want the best pump rotor, contact FinishLine Transmissions for a billet one.
On the other (high) end of the ethical and quality scale is FinishLine Transmissions. Don't worry about their official warranty as they provide top quality and service. There is only praise for them here.
Monster Transmissions has built quite the, ummm, "reputation" on the Internet if you do a little googling.
Were there any check engine lights? Codes? Anything that would command max line pressure? It could have just been a weak rotor, but they usually have help from a pressure spike of some sort. The bottom line is that the factory pump rotors, especially the 13 vane rotors, can be a problem area.
TCS makes a very nice billet steel rotor that I use on anything of a performance nature.
