tRANS SLIPS ON 2-3 SHIFT
Old Feb 7, 2016 | 09:21 AM
dartgts1's Avatar
Default tRANS SLIPS ON 2-3 SHIFT
4L60 trans on my 2002 Z/28 was slipping on the 2-3 shift under WOT. I had the trans rebuilt . They found clutches damaged. I still have the same problem after the the trans was rebuilt. Has anyone else had the same problem ? What could be the problem ? Any help would be appreciated . Thanks
Old Feb 7, 2016 | 12:37 PM
performabuilt's Avatar
LS1Tech Sponsor
Common issues with 3-4 are.
1-Green oring in input drum not changed or damaged
2-Stator tube in pump worn of damaged where input shaft rings ride
3-rings on input shaft damaged or not changed during rebuild and worn.
4-debris on encapsulated check ball in case not allowing it to seat causing leakage in third clutch oil
5-Damage or missing orifice/check valve in input drum causing leakage in 3rd clutch oil.
Hope this helps
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Feb 8, 2016 | 09:41 AM
Dynamic396's Avatar
What is your line pressure during and immediately after the 2-3 shift at WOT? What kind of 3-4 stack are you running?
Old Feb 8, 2016 | 06:49 PM
mrvedit's Avatar
Moderator
Performabuilt made an even more thorough post about this last week, where the OP had the same/similar problem. See #11:
https://ls1tech.com/forums/automatic...built-60e.html
Yes, many people have had the same problem, and I am confident it is because the builder did not carefully check every point that Frank (PerformaBuilt) lists.
I will be creating a Sticky soon so that such information is easier to find and doesn't need to be repeated over and over.
Old Feb 8, 2016 | 11:41 PM
SPRAYED 01's Avatar
You need to also consider the tune. Very possible you need to lower the mph a tad for the 2-3 shift command. It looks at mph and rpm to make a shift.
