Nylon Safe for Cooler Lines?
Old Feb 22, 2016 | 06:38 PM
Lolvo's Avatar
Default Nylon Safe for Cooler Lines?
Is the Dorman nylon fuel line safe for transmission fluid?
Just looking to use it for a short flexible run from the end of the stock hard lines to my cooler.
Thanks
Old Feb 22, 2016 | 08:56 PM
clinebarger's Avatar
Not sure what temp nylon fuel hose is rated for?, Even then...It's not designed for the application.
Gates, Parker, & Dayco all make specific trans cooler hose, I use Stepless Ear Clamps to clamp cooler hoses, Worm clamps tears up the hose casing. Fuel injection hose clamps work though.
Old Feb 22, 2016 | 09:04 PM
MaroonMonsterLS1's Avatar
gates 27058 5/16 cooler hose
made for transmission lines
any oreillys should carry a 25 foot roll and will sell it by the foot
rated to 400 psi
probably around the same price as that fuel line anyway
Old Feb 22, 2016 | 09:10 PM
Lolvo's Avatar
Dorman line is rated for 250F, more than I think I'd ever see with a stock LS1 in a 2900 lb daily driver. Pressure is less than the FI system.
My concern is ATF not reacting well with the nylon, I could see that ending poorly.
I already have -8 fittings on my cooler from another drivetrain and -6 to -8 adapters for a compression fitting on 5/16" tube, but that's alot of fittings. 5/16" to -8 aren't made.
And I have a ton of Dorman stuff left from my fuel system.
I am really space limited in the Volvo 240 tunnel and general engine bay. So I'm stuck using stock hard lines until I'm past the crank.
Old Feb 22, 2016 | 09:38 PM
250F is not enough margin even in a light car with a stock converter.
Old Feb 22, 2016 | 09:39 PM
Lolvo's Avatar
Ah okay thanks
Old Feb 23, 2016 | 06:25 AM
forcd ind's Avatar
Some of that stuff is designed for air brakes or hyd cyls., not heated oils
I use the Teflon lined hi pressure stainless for trans lines
Old Feb 23, 2016 | 08:00 AM
mrvedit's Avatar
Moderator
I've been told that the cooling line pressure can reach 1/2 of the internal line pressure.
So 1/2 of 250psi is 125psi in the cooling lines which is double that of FI pressure.
(Correct me if I am wrong and you have measured the pressure.)
Old Feb 23, 2016 | 11:11 AM
Lolvo's Avatar
I don't know about all that, I really doubt cooler line pressure ever comes close to 125 psi. Theres like 10+ feet of line in most vehicles, I doubt the pump even could maintain 125+ psi in 5/16"+ line for that distance. I'd say you're wrong by at least an order of magnitude.
You do know that 'line pressure', what the clutches and servos see off the pump, is NOT what the converter sees and DEFINITELY NOT what the cooler lines see, correct?
I contacted Dorman. The fittings are indeed rated for the pressure, temp, and ATF. They make a similar product for transmission quick disconnect fittings (like the stock fitting out of the housing) that use the same o-ring and locking mechanism, albeit with a brass rather than poly housing.
They do not however even have a temp rating for the fluid the nylon line can carry (just exterior temp), and have not tested it with ATF. Not so much a 'don't do this you will die', more of a 'this probably is not a long term solution'.
So, I'll have to bite the bullet and buy a 37deg flare tool or try some compression fittings.
