6l80e cooler line pressure
Old Feb 27, 2016 | 08:04 PM
Billy Carter's Avatar
Default 6l80e cooler line pressure
what is the 6l80 cooler line pressure supposed to be? I have a l92 / 6l80 swap in my 62 nova and I had a thrust bearing go out on crank. looks to be something in trans cause is rear side of bearing that is eat up. what controls cooler pressure?
Old Sep 23, 2016 | 02:34 PM
CF7GO's Avatar
Did you ever track this issue down? I have the same thing going on with my 5.3...TWICE. Just picked up a L96...dont want it to happen again.
Old Sep 24, 2016 | 02:30 PM
It was the cooler )Ines. I changed from 6an to 8an lines and is all good
Old Sep 24, 2016 | 02:41 PM
CF7GO's Avatar
From trans right to an aftermarket cooler? Still use the radiator as well?
Old Sep 24, 2016 | 04:11 PM
Yes I used aftermarket cooler. Not radiator
Old Sep 25, 2016 | 09:13 AM
mrvedit's Avatar
Moderator
Perhaps I'm reading this all wrong, but how the heck can the cooling line pressure affect the thrust on the crank? I'm not aware that any model automatic transmission puts significant thrust on the crank. I understand that with a manual transmission a depressed clutch puts significant thrust on the the crankshaft.
If the crankshaft's thrust bearing was toasted, I would suspect an improperly installed or built converter.
Old Sep 26, 2016 | 01:07 PM
When the cooler is restricted it causes the pressure to push the converter forward
Old Sep 29, 2016 | 05:53 AM
CF7GO's Avatar
What's the pressure now?
Old Oct 2, 2016 | 10:27 AM
About 40 to 50 psi idle goes up then back down when reving
