Oil Pan Magnets
Old Mar 7, 2016 | 04:19 PM
Paxun's Avatar
Default Oil Pan Magnets
I have a 4L60 (700R4) that was a mess inside that I am assuming is clutch material all throughout the transmission. Since I have taken so much time and and put in so much effort into this rebuild, I would like to try something better to keep the "mud" (assuming clutch material) in the pan.
Is the clutch material magnetic so that a better magnet would actually magnetize to the magnet? I found this , but would like to get some ideas from anyone that has already researched this.
Appreciate any input.
Old Mar 7, 2016 | 08:52 PM
clinebarger's Avatar
Friction Material is not magnetic, The magnet in the pan is to catch what the planetaries shed.
A healthy 700R4/4L60/4L60E will not shed much friction material anyway.
Old Mar 8, 2016 | 12:23 PM
high n dry's Avatar
I run a filter mag on outside of pan... they work great, pricy tho!
Old Mar 8, 2016 | 07:30 PM
mrvedit's Avatar
Moderator
I thought the $7 for an ACDelco magnet was crazy expensive. You can buy square foot sheets of magnet for a few dollars, which is plenty for a dozen transmissions and plenty left over. You just cut the thick sheets with scissors. Some even come with adhesive if you have an aluminum pan.
Old Mar 8, 2016 | 10:16 PM
sjsingle1's Avatar
this ! i use a truck pan so i can locate it in the shelf area and not worry about it being scraped off
