Need some help
Old Mar 11, 2016 | 10:39 AM
Petes50's Avatar
Default Need some help
I have a 1950 powerglide getting rebuld and the input shaft is stuck in the planetary assembly
Old Mar 11, 2016 | 11:08 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
Is this a core you're rebuilding or a fresh running unit?
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Mar 11, 2016 | 11:45 AM
Petes50's Avatar
It's the one that was in it ,it drove but didn't shift good so I took it to get rebuld the shop is having trouble getting the shaft out
Old Mar 14, 2016 | 08:53 AM
LS1Tech Sponsor
That is odd. I would check the planetary and input shaft once you get them apart for a bur, rust, or possible a twisted splines. The input shaft should be able to float within the transmission and the converter.
__________________
1-866-726-8358
FTIPerformance.com
