** FTI stall converter Guys Come in **
Recently installed an fti hard hit 3800 in my ls1/4l60e Monte Carlo, it feels noticeably looser cruising around town than the factory one, is this typical or possible I’ve damaged the trans at all? I’m probably just being paranoid but I thought the converters for the newer overdrive trans acted a little tighter around town than the older stuff with th350/th400’s
The torque multiplication, STR/ Stall torque multiplication ratio... must have been gone over with you, if you spoke to a sales person at FTI.
The softer-hit version of your torque-converter would not feel so loose in comparison... but stall speed is also a factor.
What he said ^^^^^^^^^^
Thanks Vortec!
Thanks Vortec!
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
