th400 yoke question
http://www.summitracing.com/parts/tci-965300
If your DS has a 1310:
http://www.summitracing.com/parts/tci-965310
If your DS has a 1350:
http://www.summitracing.com/parts/tci-965350
the 1310 or 1330 will not bolt up to the 3R pinion yoke....
specs of the 3R/S44 joint: lock up=2.556 (inside) bearing dia.=1.125"
specs of the 1310 joint: lock up=3.219 (outside) bearing dia.=1.063"
specs of the 1330 joint: lock up=3.622 (outside) bearing dia.=1.063"
And two of these U joints?
http://www.summitracing.com/parts/tci-961300
then get them installed...drive shaft cut and balanced?
Just want to make sure before i place the order.
