TH400 Leaking from plug
Old May 5, 2016 | 07:27 PM
jrpimp00's Avatar
Default TH400 Leaking from plug
My new TH400 is leaking from the plug in the pic. I think an O-ring goes around it, anyone know the size? I would like to pick one up before I pull the old one. Been chasing what I thought was a pan leak, and 5 gaskets and 6 fluid drains later I finally see my problem.
Old May 7, 2016 | 11:29 AM
john kilgore's Avatar
any trans shop should have it, it is the same on the 2004r old plastic sometime shrinks so l wouldn't be afraid to use hi temp silicon also
Old May 7, 2016 | 09:07 PM
jrpimp00's Avatar
Hopefully I got it fixed. The one on the right was the one leaking. The O-ring seems to be almost half the size as the one I pulled from another trans.
Old May 7, 2016 | 09:09 PM
jrpimp00's Avatar
You can see better in this pic. But its rotated, so the one on the left is the leaky one
Old May 9, 2016 | 06:21 AM
forcd ind's Avatar
Someone prob put the wrong o ring on it
Old May 9, 2016 | 12:59 PM
unit's Avatar
O ring on the left doesn't fit the recess very well. Looks like you should be good!
