Rebuilding 4L60e, part recommendations
Old Jun 6, 2016 | 03:21 PM
98greenT/A's Avatar
Default Rebuilding 4L60e, part recommendations
I'm rebuilding my 98 4L60e, I want it to hold up to 600hp and 600tq range.
What kits has everybody used, pro and cons. Do I need to upgrade to 5 gear planetary? Beast sun shell, sonax input shaft? New solenoids?
Old Jun 6, 2016 | 09:22 PM
clinebarger's Avatar
I want it to hold up to 600hp and 600tq range?
Good Luck, You will need it if you abuse it daily & want it to last more than 20-30,000 miles without a refresh.
What kits has everybody used?
Don't use "Kits", I buy what I need.
NO!!!! I run the 5-Pinion Input Carrier quite a bit because it doesn't cost much more the a 4-Pinion, Watch for the Bearing change on new Delco Input Carriers.
For the Reaction Carrier I run a Delco High Speed 4 Pinion...Which is stock on all V8 4th gen F-bodies.
The most important thing is to run New Delco Or Good Used OEM/Delco. (The Sonnax "Ratio Change" 6-pinion Input Carrier is a nice piece)
Beast sun shell?
I would run a Sonnax Smart Shell.
sonnax input shaft?
NO! Upgrading the Output Shaft is more of a priority.
New solenoids?
Yes, Delco.
Old Jun 6, 2016 | 11:19 PM
MaroonMonsterLS1's Avatar
8 clutch borg warner high energy 3/4 clutch setup (i prefer kolene steels)
Red alto's for the rest.
29 element sprag
sonnax smart shell
sonnax smart-tech input drum
13 vane pump
shift kit
.500 sonnax boost valve
2 5/8" wide carbon band (NOT KEVLAR)
sonnax billet 2/4 servo
new case bleed capsule
transgo hd-2 shift kit
accumulator spring upgrade
rubber molded apply pistons
one piece teflon seals wherever applicable
new bushings/seals
hardened output shaft
5 pinion platetaries
BIGGEST COOLER YOU CAN POSSIBLY RUN!
there's probably a couple little things I forgot to mention that others will remind you of, but that should get you started.
Old Jun 7, 2016 | 08:43 AM
98greenT/A's Avatar
Do you buy all this stuff from one vendor or source it from multiple?
Old Jun 7, 2016 | 09:45 AM
I'm from Iowa so I go through Midwest Transmission Supply. Just a very large distributor for a lot of trans shops around here and I you can set up an account and order stuff for yourself too. Better prices than anywhere you'll find on the net. Otherwise there are plenty of sites and vendors that are sponsors here that can get you all of that list.
Old Jun 16, 2021 | 06:14 PM
matermark's Avatar
I know this is an old thread but Maroon, were you talking about the place in Omaha, NE? It says MTS is offline...
Thanks.
Old Jun 16, 2021 | 09:16 PM
vorteciroc's Avatar
Disregard Post #3... Maroon Monster's recommendations there are outdated.
He would provide different recommendations today.
Old Jun 17, 2021 | 09:50 AM
matermark's Avatar
I hope he makes corrections but I would guess:
5-pinion planetaries
Red altos?
10 vane instead of 13?
Did I miss anything?
