4wd boost launch with 4l80e?
Old Jun 15, 2016 | 10:37 AM
bluestreak308's Avatar
Default 4wd boost launch with 4l80e?
My plan is to turbo a 2005 5.3 single cab short box 1500 GMC. I am shooting for 650-700 rwhp. I will be swapping in a built 4L80E trans. My question is this. should I go with a 4wd or a 2wd? If 4wd will the drivetrain hold 4wd boost lauches at the track? Or should I just run 2wd and slicks? Any advice is appreciated. This truck will be a DD.
Old Jun 20, 2016 | 08:17 AM
Troy5061's Avatar
4wd will be fine, search for info on stock48, parish or atomic. Those guys have been doing it for years. Either way your gonna need a truetrac or better locker in the rear because the stock one wont hold up. I would also recommend getting a stout rear driveshaft either way you go.
Old Jun 20, 2016 | 09:03 AM
67Lark's Avatar
My vote is do it regardless, what's the worst that could happen, it breaks? Oh well, it was fun now rebuild it.
