4l80e Accumulator Delete
Old Jun 19, 2016 | 05:35 PM
simman22's Avatar
Default 4l80e Accumulator Delete
I was wondering if you could remove the 3rd and 4th check ***** when you delete the accumulator set with Jake's block off plate. I tried searching around but couldn't find a definitive answer or if it even matters. Thanks in advance!
Old Jun 19, 2016 | 07:15 PM
jakeshoe's Avatar
You can delete both the accumulator checkballs when using the block off plate.
Old Jun 19, 2016 | 08:31 PM
simman22's Avatar
Awesome, thank you sir!
