Output shaft rotational endplay?
How much rotational end play is normal from the output shaft on 4l60e?
When I grab the yoke and turn it back and forth with transmission in neutral, it rotates about 1-2 degrees before it grabs. This is a fresh rebuild only 200 miles on it.
When driving at highway speed with converter locked, going on and off the throttle results in a clunk you can feel on your feet in the car. Its like a bad U-joint except mine are brand new.
Any thoughts or help would be appreciated
Thanks
Paul
If it ends up being the trans, It goes to show that careful inspection of ALL components is a very important part of rebuilding a transmission!
I will be going through everything you mentioned shortly and tightening everything up if needed. Plan on prothane transmission mount as well. Already have poly engine mounts.
thanks
Paul
