Th400 speedometer removal
Old Jul 10, 2016 | 10:07 AM
wichoms4's Avatar
Default Th400 speedometer removal
Hi guys have not posted in a great wail. I am currently doing a th400 swap on my F body. I want to remove the speedometer. Can I do that and just place a plug? Will the internal speedo gear hang loose or even come off internally during operation?
Thanks,
Th400
Old Jul 11, 2016 | 09:03 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
You don't have to remove the gear you can just plug it. IF you do want to remove the gear(plastic one) however all you have to do is pull the tail housing to get it off.
-Dalton
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Jul 11, 2016 | 06:50 PM
wichoms4's Avatar
-Dalton
Thanks. I was worried the internal gear would come loose and cause damage.
Old Jul 12, 2016 | 07:25 AM
LS1Tech Sponsor
No sir you should be just fine!
-Dalton
__________________
1-866-726-8358
FTIPerformance.com
