N/A converter with spray.. When to lock-up?
I'm thinking locking the converter sooner might be a good thing for spray because when it's blowing theough the converter obviously thats going to hurt my times... Please share your info! The converter is a circle d 5c btw
I'd like to lock it as soon as possible, but there must be downsides to locking the converter early or everyone would be doing it? Or maybe not.. I have it set to lock right now at 97mph both on my n/a tune and my n20 tune. I would like to lock it in second gear if possible
Will you be fine? I'm not quite sure but that's the way it was explained to me before. I hear you on the NA goal but once you hit it you're bummed because on spray your setup isn't as efficient
anything for you. Efficiency goes up but torque multiplication
takes a hit - which gives you the best result (leaving aside
mechanical failure)? This here, varies a lot with the converter
design (how much torque mult remains at trap RPM/MPH?).
On a higher stall speed converter, probably a significant
amount (was obvious w/ my 3500/2.0 converter, how much
acceleration dropped from unlocked to locked @ 5000RPM).
