Orange and black wire on the pnp switch
Old Jul 27, 2016 | 09:54 AM
02anti_vnm's Avatar
Default Orange and black wire on the pnp switch
Hey guys I'm doing a manual to auto swap using a stock shifter and PNP switch. After looking at diagrams for the switch I know there are 6 wires. 2 for the park neutral that I'll be wiring into the old clutch switch wires. Two for reverse lights, one for the shift lock that I won't be using and lastly the orange wire with black stripe that goes to the PCM.
Does anyone know where to wire this in at on a factory m6 body harness? Just the orange and black wire is what I'm wondering about.
Old Jul 27, 2016 | 10:38 AM
bbond105's Avatar
It goes to the In-Line Connector C220 behind the right front kick panel in front of the door. The orange and black wire goes to the H terminal of the C220 Connector.
Attached Thumbnails Orange and black wire on the pnp switch-orn-blk-wire-park-neutral-position-swicth.gif   Orange and black wire on the pnp switch-parkneutral_back-up-switch.jpg
File Type: xls
Old Jul 27, 2016 | 07:23 PM
02anti_vnm's Avatar
I have orange and black on the body side of the harness but it is in F. On the engine side of the harness there is no Orange and black wire.
In H I have the green ground wire for the reverse lights
Also looking at the schematic it looks like it goes to pin 34 on the blue pcm plug. I don't have anything in pin 34. Am I going to pin this in or do I not need this anyways
Old Jul 28, 2016 | 10:31 AM
bbond105's Avatar
What year is your car?
Old Jul 28, 2016 | 01:33 PM
02anti_vnm's Avatar
It's an 02
I think I'm just going to get a pin for the PCM and run a wire from the orange/black wire at the switch to the pcm and plug it into spot 34 on the blue connector
Old Jul 29, 2016 | 09:08 AM
bbond105's Avatar
What color wire is in pin 34 at the PCM?
Old Jul 29, 2016 | 11:45 AM
02anti_vnm's Avatar
Pin 34 was empty. I went to the junk yard and pulled a wire and pin from a PCM on a truck (orange/black wire because I wanted them to match) and pinned it into the PCM and then ran it to the pnp switch. That sound right?
Old Jul 29, 2016 | 02:05 PM
bbond105's Avatar
That should work. That is strange though, my 02 WS6 had the wire already in place.
Old Aug 1, 2016 | 10:53 AM
02anti_vnm's Avatar
Was it an auto car though?
Old Aug 1, 2016 | 01:11 PM
bbond105's Avatar
M6 car that I swapped to a 4L60E.
