4l60e need help ASAP thanks
Old Aug 11, 2016 | 01:35 PM
Marcos Garza's Avatar
Default 4l60e need help ASAP thanks
Having trouble with my tranny . I'm driving around town and my partial lock up doesn't want to kick in and in every stop the truck takes a long time to move like if it was forced. when that happens my towing hual doesn't work either.. I have to turn off the truck to make it work again normally.. also when I step on it all the way it works good for like 5 sec and then it bogs down bad for 3-4 sec and then it works back. Idk if its slipping already. Tranny was rebuilt last year (4l60e) new shift solenoids with harness and tcc.
Old Aug 11, 2016 | 04:48 PM
mrvedit's Avatar
Moderator
The first step is to scan for codes.
The 2nd step is to hook up a pressure gauge to see what the pressures are while driving, accelerating, etc.
Old Aug 13, 2016 | 12:10 AM
BubaGumpShrimp's Avatar
was a shift kit installed or a high stall converter
Old Aug 17, 2016 | 10:03 AM
performabuilt's Avatar
LS1Tech Sponsor
Sounds like Limp mode as mention check for codes also if a high stall converter over 2500 rpm was installed some tuning may be needed to prevent false codes setting limp mode.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
