4l60e using tci-374090 help
Old Aug 22, 2016 | 07:13 PM
Rick Speed's Avatar
Default 4l60e using tci-374090 help
I.m replacing my clutch pack with this kit and it says its a direct fit but it will not fit on a dry test run to get the snap ring in. do the clutches shrink when wet or am I missing something.
Old Aug 22, 2016 | 08:04 PM
clinebarger's Avatar
I had to look that up.....It's a Alto "Commercial/Tan" Power Pack. But without the components too make it work??? The Alto set-up comes with different thickness steels, Thin Snap Ring & a Thin Backing Plate.
I guess it's a good thing as that **** is TRASH. Try this, Works in most 4L60E Input Drums with a V8 3-4 Clutch Apply Housing Ring.....
7 Borg Warner .080" High Energy Frictions.
6 .077" Kolene Threated Steels.
3-4 Apply Plate GM# 8685044
3-4 Backing Plate GM# 24212460
Frictions swell a little when soaked in ATF.
Old Aug 22, 2016 | 08:15 PM
Rick Speed's Avatar
where can I find those steels? I'm having trouble searching for those.
Old Aug 22, 2016 | 08:34 PM
98CayenneT/A's Avatar
http://www.makcotransmissionparts.com/74120AK.html
