Trans temp gauge question
Old Oct 12, 2016 | 04:23 PM
TXCatfish's Avatar
Default Trans temp gauge question
Is there a way I can install this in the pan without welding a bung?
Can I use a nut on the inside and somekind of washers to prevent it from leaking? I heard crushing washer or fiber washers may work.
Old Oct 12, 2016 | 04:32 PM
98CayenneT/A's Avatar
This is the one I have. Drilled a hole in the side of my pan. Used red thread lock on the inside nut and the plastic washer goes on the outside of the pan.
https://www.amazon.com/Derale-13010-.../dp/B000CJ0626
I use this to drain fluid and for my transmission temp sensor port
Old Oct 12, 2016 | 04:37 PM
Couple pictures
Old Oct 12, 2016 | 05:01 PM
TXCatfish's Avatar
Okay I think that is similar to what came with my gauge. It has two adapters with holes that the sending unit fits in. I guess I could take the sending unit out to drain the fluid. Here are a couple pics.
The 3rd pic is with the sending unit is in the adapter. It doesn't stick out all the way out the bottom, wasn't sure if that was a problem. If this will work I guess I just need a nut for the inside and a plastic washer for the outside?
Thanks!
Old Oct 12, 2016 | 05:18 PM
Yes sir. Your local auto parts store will carry the plastic washers you need. Usually in a pack of 5 like shown below. Also red thread lock that inside nut
Old Oct 12, 2016 | 05:20 PM
Also, you probably will never really have to remove it once installed but if you ever do always use a new plastic gasket/washer
Old Oct 12, 2016 | 05:32 PM
01ssreda4's Avatar
I have a stock pan with a welded bung and drain id give you.
Old Oct 13, 2016 | 08:26 AM
TXCatfish's Avatar
Perfect, thanks!.
Man I appreciate it! If this doesn't work for some reason I will get with you.
Thanks alot bud!
Old Oct 17, 2016 | 08:14 PM
PBA's Avatar
PBA
I prefer to see it on the return line (top line). That way you get "real world" (instantaneous) readings, not delayed as in the pan or case.
