late 4gen fbird 4l60e problem in D
I need help for my LS1 firebird (2000).
Problem: my engine stops when I break.
- it happens when:
- my engine is warm
- the rpm was more than 1000 before the breaking
- the transmission is in D
- i can avoid this if i set the transmission to N before i start to break.
- it happens very frequently now (at every 2nd red lamp)
- i can't reproduce it when my trans in 3
thanks for your help
I think, I will exchange the full valve body to a remanufactured one (I saw some on ebay). Is it a good idea? My car has 160.000 miles. I used it on high ways.
A separate TCC solenoid that you wire into the harness shouldn't be hard to find; I think the 700R4 used the same one. This looks like the right one for $15:
https://www.amazon.com/4L60E-700-R4-...6XI/ref=sr_1_4
You can simply splice it in - nothing fancy because ATF does not hurt exposed wiring.
(I found it by searching for "4l60e tcc solenoid")
Of course at 160K miles you might consider a new harness which includes the TCC solenoid for $35, partly to be sure your harness doesn't have a short. Replacing the harness typically requires removing the 1-2 accumulator housing, the Pressure Control Solenoid and then unsnapping the harness connector.
It is always interesting to see how many suspected transmission problems are due to an engine/sensor problem.
It did sound like your TCC was sticking, but obviously it was not in this case.
Anyway, glad you figured it out.
