Which Trans. 4 '50 Truck
Old Jan 27, 2017 | 03:57 PM
dlee's Avatar
Default Which Trans. 4 '50 Truck
My son & i are building a '50 Chevy 3100 truck, we plan on using a LS2 or LS3 engine. Which transmission would be recommended, have 10 bolt rear with 3.42 gear, could change to 3.73. I've read for several hours here & i don't want to use the 6l80.
Have access to 700R4, how does this compare to the 4L80E?
Thanks In Advance
Old Jan 27, 2017 | 04:29 PM
wht/73's Avatar
I just put an 80E in my nova.
The 80E is a big trans. I'm pretty hard on trans's so I went with the HD trans.
I probably could have gotten away with a BUILT 4L70E (electronic 700) at my power level but the 80E is much stronger in stock form.
What is your intent for this truck?
The pro's will chime in. I just figured I'd start.
Old Jan 27, 2017 | 04:37 PM
dlee's Avatar
The truck will be a weekend driver, will not be a show truck.
Old Jan 27, 2017 | 04:39 PM
wht/73's Avatar
Probably be fine with the 700 but I prefer the electronic trans tho.
Old Jan 27, 2017 | 05:07 PM
dlee's Avatar
Forgot to mention i have a T350 in the shop w/BTE converter i removed from my '70 Nova footbrake drag car. Wouldn't have o.d., but wouldn't have to spend the money for another trans either. Also, wouldn't require any wiring other than speedometer, i think?
Old Jan 27, 2017 | 05:09 PM
wht/73's Avatar
That's a good option too! I just gave my t350 with my 8" converter to my son for his Malibu with a 406 and 3.42's
He loves it over the 200 it replaced.
Old Jan 27, 2017 | 07:22 PM
mrvedit's Avatar
Moderator
Are you using a mechanical or electronic speedometer?
A matching trans will simplify hooking up to the speedometer.
If electronic speedometer, a junk yard 4L80E might be all you need.
If mechanical speedometer, the TH350 might be fine if you can live without OD.
Old Jan 28, 2017 | 02:55 AM
tfi racing's Avatar
Unless your plan is long interstate highway trips,go with the TH350 you already have.You will have plenty of opportunity to spend the cash you saved for an OD trans on other parts of your build.Yes,that is a 53 GMC in my avatar,6.0 and TH400 going into that one...
