Th400 build thread.
Old Dec 12, 2016 | 06:43 PM
  #41
Game ova's Avatar
Originally Posted by Jays_SSZ28
You mean it does not have a sprag on the direct drum.
Has a roller clutch on the on the reaction carrier, most do, except 1964 and 1965 th400's. I used to run a 36 element sprag there, found a low mileage reaction carrier. Usually 1965 and low mileage don't exist these days. I don't know that the roller clutch there is a high failure item.
You're right about keeping the 32 spline output. You're going to need a counter bored yoke (not yolk). Makes no sense to track down a 28 spline output shaft and extension housing.
Think it's necessary to bolt the yoke to the output shaft? I ask because the yoke was seized to the output shaft and I had to impact it off and in the process jacked up the threads beyond repair. It seems you know transmissions fairly well, so what do you set your forward and direct clutch clearances to? Sorry bout all these questions, but I'm definitely a noob with transmission internals.
Old Dec 12, 2016 | 09:00 PM
  #42
Jays_SSZ28's Avatar
You bolt the yoke to the output shaft you end up with a broken trans case.
As the rear suspension moves up and down the yoke moves in and out of the transmission. On a truck the slip yoke is in the middle of the driveshaft, thats why the yoke can be bolted on.
With a th400 I'd set all the clutches to .040 or close, it's not like a 4L60E where clutches come on and release during some shifts. On this trans you don't have to worry about shift overlap. Forward is always on when it's in drive so it can vary quite a bit and be ok.
I'd also leave all the waved plates in.
Old Dec 13, 2016 | 07:50 AM
  #43
FTICONVERTERS's Avatar
LS1Tech Sponsor
You mean like one of these here?
Hardened billet with bolt on straps for easy removal.
http://ftiperformance.com/product/th...er-yoke-f4054/
FREE SHIPPING From now until we close for the year on Dec. 23rd too!
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Dec 13, 2016 | 04:29 PM
  #44
Game ova's Avatar
Ok, so I got the case, pan and pump cleaned up today. Pulled the pump apart and the gears looked fine. I'm not sure if it's good practice to replace as needed, or just do it anyway since I'm already here. Thoughts?
Old Jan 16, 2017 | 05:59 PM
  #45
Game ova's Avatar
Ok, haven't done anything with the car for the past couple of weeks. Reason is, it was playing time AKA vacation. Below had been my scenery. So I came back home with renewed interest in the car, planned to bang out this Th400 tonight.....and hit a snag. Transmission store sold me the wrong torrington bearing, and stopped me in my tracks. Should be able to finish up by tomorrow. This has been dragged out far too long, and now I'm itching to get the car back in action.
Old Jan 17, 2017 | 12:43 PM
  #46
382ssz28's Avatar
I've been in the business for 40 years. This requires a phone call. There are myths and mistakes from so many. This should only be about doing the trans the right way.... Not about the money.... I am offering you some valuable info... Because i love the job....
Pm me for my number.... Brian
Old Jan 17, 2017 | 12:59 PM
  #47
Game ova's Avatar
You have a pm.
Old Feb 7, 2017 | 12:29 PM
  #48
Game ova's Avatar
Just wanted to update. Tranny is done, cut the ears off this morning. Crossmember should be here either today or tomorrow, and the install will be this weekend.
Old Feb 7, 2017 | 08:43 PM
  #49
Launch's Avatar
Another 'n T400.
Old Feb 10, 2017 | 09:45 PM
  #50
Game ova's Avatar
400 is installed. Need to mount the cooler and shifter. Will see about having a driveshaft made next week.
Old Feb 10, 2017 | 10:03 PM
  #51
MY_2K_Z's Avatar
Summit does driveshafts for like $200
Old Feb 10, 2017 | 10:23 PM
  #52
Game ova's Avatar
They steel or aluminum?
Old Feb 10, 2017 | 10:25 PM
  #53
MY_2K_Z's Avatar
Chromoly I believe
Old Feb 10, 2017 | 10:26 PM
  #54
Game ova's Avatar
Chromoly I believe
Will have to check that out then, that's not a bad price.
Old Feb 10, 2017 | 10:31 PM
  #55
MY_2K_Z's Avatar
It's $250 now. Strange chromoly
https://m.summitracing.com/parts/str-u1699
Old Feb 13, 2017 | 03:14 PM
  #56
fastsspr's Avatar
Im in the process of stop my car to do the swap from 60e to th400. I find out some interesting info. for the DS. I can not share the link here because they are not sponsors here. I going to PM you the Info.
Old Feb 13, 2017 | 07:51 PM
  #57
Game ova's Avatar
Default Expensive flywheel and yet.....
So, I had planned on finally starting the car today to see if this transmission works. Went to bolt up the converter, but found the holes to be too small. Now Just on principle alone I feel that an expensive sfi flywheel should not require any customization whatsoever....no, its not the end of the world but still. Opinions?
Old Feb 13, 2017 | 08:41 PM
  #58
soloman369's Avatar
So you didn't notice how big the converter bolts were beforehand? FTI converter bolts that they Supply with their converters fit my 98 flex plate just fine. Only thing I needed was that pilot extension.
Old Feb 13, 2017 | 08:48 PM
  #59
Game ova's Avatar
Evidently not. And I'm not using Fti, or a 98 flywheel.
Old Feb 13, 2017 | 09:02 PM
  #60
soloman369's Avatar
Just drill it. It's not going to hurt nothing.
