98 chevy 4l60e transmision
Old Dec 20, 2016 | 10:08 PM
Wesley Houldridge's Avatar
Default 98 chevy 4l60e transmision
I have a 98 chevy tahoe 4x4 with a 4l60e . on my way to work one day I killed it went inside the gas station and when I come out it wouldn't go into 1st. it dropped 1st 2nd and reverse . 3rd still works. I need some help. I know nothing about trans and no one seems to have this problem . Or knows how to fix it. Any suggestions ?
Old Dec 22, 2016 | 09:06 AM
bbond105's Avatar
Are you saying that reverse doesn’t work also? Check the fluid level and the shift linkage. Is the fluid burnt? That is an odd combination of problems. Maybe time for a rebuild.
Old Dec 22, 2016 | 09:55 AM
The fluid is good not burnt and the linkage is fine. 3rd and 4th both work. It doesn't show any electrical codes. I guess it's time for a rebuild. Thanks tho for your info. Much appreciated.
