Th400 forward drum inner seal
Old Dec 26, 2016 | 01:34 PM
Game ova's Avatar
Default Th400 forward drum inner seal
Ok, so I've been trying to seat this piston in the forward drum off and on for a few days now. It's just not working out. So, my question is...is the inner seal necessary? I ask for a couple of reasons, one is..I know that the one on the direct drum isn't needed, as it only means a harsher engagement. Just wondering if the same is true for the forward drum. I'm sick of fighting it. Btw, I've tried the rubber band freezer method....lube...all of it.
Old Dec 26, 2016 | 05:02 PM
Jays_SSZ28's Avatar
You are using an aluminum piston right? Inner seal lip side up?
I've never had a problem with the inner seal. Did you match up the number on it with the old one?
Try installing the piston with only one seal at a time, maybe it's not the inner giving you a problem?
Old Dec 26, 2016 | 06:32 PM
PBA's Avatar
PBA
I agree, I have never had a problem installing one. Leaving out the inner seal will make for a harsh forward engagement. The lip goes upward as stated.
Old Dec 26, 2016 | 07:00 PM
Game ova's Avatar
Originally Posted by Jays_SSZ28
You are using an aluminum piston right? Inner seal lip side up? And this may very well be the problem. I installed the seal lip down like the inner and outer on the piston.
I've never had a problem with the inner seal. Did you match up the number on it with the old one? And here's another mistake I've made, searched the garage, but can't find it. I think me having it upside down might be the issue.
Thanks, will be trying it installed the right way when I get home tomorrow.
Old Dec 28, 2016 | 04:33 PM
Game ova's Avatar
It's amazing how easy the piston fell into place with the drum seal facing the right direction......yea, I had it in backwards.
