Converter identification help
Old Jan 17, 2017 | 10:17 PM
Turboni's Avatar
Default Converter identification help
All this converter says is "LS SINGLE 258MM 7-1092 it's brand new and has an fti sticker on it. It's been on my shelf too long to remember what it was for. The base of it is billet so I think it's a higher end converter.
Old Jan 18, 2017 | 07:56 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
This is one of our competitors converters that we re-stalled, made like one of ours, or freshened up.
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Jan 18, 2017 | 12:03 PM
Turboni's Avatar
Ok thank you! Is there any way by looking at it to tell roughly what stall it is?
Old Jan 18, 2017 | 12:37 PM
Turboni's Avatar
Also what's weird is I count 40 splines when I look in it on the input shaft. Sorry it's actually 36 splines!
Old Jan 18, 2017 | 01:01 PM
LS1Tech Sponsor
On the side of the converter that goes inside the transmission... there should be 4 numbers stamped in it.
for example 3082, 0391, 8082
EDIT: On the splines double check you're count... the smaller diameter set of splines should be 30 spline if it's still for an LS(98'-Up 4L60E) style input.
-Dalton
__________________
1-866-726-8358
FTIPerformance.com
Old Jan 18, 2017 | 02:37 PM
Turboni's Avatar
The only numbers stamped on it are 19 and that's on the side that goes into the transmission. As far as the smaller splines there are 36 of them. I went home and counted them 3 times lol.
Old Jan 18, 2017 | 03:40 PM
LS1Tech Sponsor
Sorry I saw LS single and assumed 4L60E... the 36 spline is for a 6L80E transmission.
__________________
1-866-726-8358
FTIPerformance.com
Old Jan 18, 2017 | 05:12 PM
Turboni's Avatar
Thanks a ton for your help fti!
Old Jan 19, 2017 | 07:25 AM
LS1Tech Sponsor
Not a problem!! Let us know how that converter works out for you.
__________________
1-866-726-8358
FTIPerformance.com
