DIY 4L60E rebuild possible??
Here is what I am working with; a 4L60E TCI trans that I am fairly certain is good. BradWS6 gave it to me when he went to a TH400 set-up. The trans only has 2 runs on it since it was "freshened' up. Only known issue is it won't shift from 1-2 without letting up on gas. Brad is fairly certain it is/was a cut wire in the harness or PCM.
I would like to take the trans apart and make sure everything is OK. Basically just give it the "once over". What is this on the "difficulty" scale? Should I attempt this on my own or just take it to a trans. shop? Any parts I should upgrade? Any advise, or help is greatly appreciated!
Darrin
It was the input shaft sealing rings that got goofed up. I'm willing to bet the 1-2 shift problem isn't an internal problem, but a programming issue, or low fluid level.
