reuse this input drum?
Old Feb 12, 2017 | 08:34 PM
Karlw's Avatar
Default reuse this input drum?
4l70e from a 2wd TBSS with 55k on it. The lugs pictured are wiped clean and the fwd/overrun lugs below are marked up the same way. Should I reuse this drum or replace?
Old Feb 12, 2017 | 10:43 PM
mrvedit's Avatar
Moderator
This looks normal and fine to me, but I will defer to the pro builders here.
Old Feb 13, 2017 | 05:59 AM
bbond105's Avatar
Looks good to me.
Old Feb 13, 2017 | 06:22 AM
98CayenneT/A's Avatar
Mine looked like that if not a tit worse. I sanded it down a bit to smooth out the burrs and give me a warm and fuzzy feeling lol.
I am far from a expert but to me it makes sense to at least knock down any burrs.
Old Feb 13, 2017 | 09:23 PM
Karlw's Avatar
Great! I'll clean the lugs up a bit and carry on.
Old Feb 15, 2017 | 03:50 PM
performabuilt's Avatar
LS1Tech Sponsor
File down the rough spots you will be fine
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
