Suspect Failing Torque Converter
Old Feb 18, 2017 | 04:57 PM
Jeffrey L. Hansen's Avatar
Default Suspect Failing Torque Converter
I have a 2000 z/28 automatic and have a problem with it. It can start moving and even gain speed, but it will engage/disengage and finally quit engaging entirely. It initially happened on the freeway after some spirited passing, etc. Prior to the issue, I noticed an intermittent scraping noise at idle, in park and neutral, but it started doing it in Drive, too. Since it happened in Park, I figured it could be Torque Converter or Pump issues, but the slipping was either unrelated to the noise or the slipping was part of a Torque Converter problem. Could someone help me figure this out? I don't want to shell out for a transmission if it's just the TC, but don't want to drop the tranny twice, if it's not. Everything is stock and has about 200k miles on it.
TIA
jeff
Old Feb 18, 2017 | 05:50 PM
Doug G's Avatar
fluid level ?
last filter change ?
ever been rebuilt ?
Old Feb 19, 2017 | 01:31 PM
performabuilt's Avatar
LS1Tech Sponsor
Drop the pan and see whats in there would be the first thing to do,
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Mar 5, 2017 | 02:25 AM
jlhansen's Avatar
Originally Posted by Doug G
fluid level ?
ever been rebuilt ?
I haven't done anything to it for quite a while. I'm just trying to see if there is a symptom specific to failing converters. I'm pretty sure the fluid level was one of the first things I looked at, but it's been so long that I think I'll look again.
Old Mar 5, 2017 | 02:27 AM
jlhansen's Avatar
I should probably try that. Are you saying that I'll definitely see trash in the pan if the trans failed?
Old Mar 5, 2017 | 11:18 AM
SidewaysTA's Avatar
Oh yeah, most definitely. Take a picture of what you find and post it and they can most likely pin point where the problem is.
