patc 6 pinion planetary
Old Feb 27, 2017 | 10:22 AM
lt13831996's Avatar
Default patc 6 pinion planetary
anyone on here ever try this set-up? changes gear ratio in trans 1st & 2nd. does it really shave. 2-.3 ths off ets?
Old Feb 27, 2017 | 11:33 AM
sillysspeed's Avatar
I started a thread on here about a month ago about this. No one could really give me a solid answer on if it made a difference on the timeslip. It should make traction easier to come by though. My opinion is that it will help a bit on high powered setup's and also on lighter cars with alot of rear gear (4.10 and up).
I bit the bullet and ordered one. This spring and see what kinda difference. I will have the same converter but the car will be around 80lbs light but I will factor that along with the weather in.
Old Feb 27, 2017 | 05:05 PM
mrvedit's Avatar
Moderator
Yeah, several threads on it.
I have a close-ratio 6 pinion planetary. While I like it for street driving, I was not able to document any ET improvement at the track. Since I often have traction problems it did help with that.
Old Feb 28, 2017 | 07:31 AM
lt13831996's Avatar
I seen there were some other threads started but no solid answers. there about half the cost now. my car is a 383 le2 h/c/I car 3.90 gear auto 11.80 car right now. 3500lbs. might have bite the bullet and try it.
