TH350 vs. TH400 Case/Interchangeability?
Old Mar 16, 2017 | 10:05 AM
gregjo1948's Avatar
Default TH350 vs. TH400 Case/Interchangeability?
Do the th350 and th400 use the same case and can they be interchanged without alterations? Thanks, gregjo1948
Old Mar 16, 2017 | 12:24 PM
82cetuner's Avatar
a th350 is like a 4l60e and a th400 is like a 4l80e the actual size is the biggest difference. kind of like a 10 bolt to a 9 inch lol. a th350 is plenty strong for most peoples applications, a th400 has the benifit of more reliability and probably wont have to be torn down and rebuilt as much as a th350 on big horsepower. it really comes down to what you plan for the car
Old Mar 16, 2017 | 02:01 PM
gregjo1948's Avatar
Would anyone know what trans. would be in my 1978 Chevy 1/2 ton 4x4
350 cid? It's been taking 15 minutes to move after it sets for a day. Now it doesn't move at all. The tranny fluid is dark and smells burned. Is the tranny shot or is it the converter?
Thanks, gregjo1948
Old Mar 16, 2017 | 07:37 PM
bbond105's Avatar
Most likely the trans is shot. The dark and burnt fluid comes from clutches, most 350/400 torque converts did not have clutches in them until the later models. The turbo 350 has a modulator valve at the rear of the trans and points to the rear of the vehicle. The turbo 400 has a modulator valve on the side of the trans and points to the side. And no they are not the same case.
