Help with 4l80e swap
Old Apr 3, 2017 | 06:42 PM
rossi89's Avatar
Default Help with 4l80e swap
Hello i am in the process of swapping a 4l80e in my car. The motor is a 2003 lq4 6.0 and previously had a t56 behind it. Today I installed the TCI 399753 flexplate with no spacer. Before going any further I just want to double check that no spacer is needed. 6.0 - TCI 399753 - 4l80e 6 bolt yank convertor spacer or no spacer? Thanks for any help.
Old Apr 4, 2017 | 08:03 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
That looks to be a dished flexplate which would mean no spacer. Just make sure your yank converter is setup with an LS pilot or you have the LS pilot adaptor and you should be good!
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Apr 4, 2017 | 10:02 AM
rossi89's Avatar
Thank you very much!
