Trouble removing 4l60e
If the transmission has never been out or has not been out in a long it can be a bear to get it off the dowls.
You remove 8 bell housing bolts and 3 converter bolts correct?
If so just a little more muscle is needed. You will see at about 3 and 6 o'clock are the dowls, get a screwdriver in there prying going back and forth between each side.
