Th400 direct piston....with a 4L80 drum?
Old Apr 17, 2017 | 10:31 AM
Game ova's Avatar
Default Th400 direct piston....with a 4L80 drum?
Do these two interchange?
Old Apr 17, 2017 | 06:54 PM
Game ova's Avatar
By the looks of "the transmission section", if I was inquiring about a 4L60e....I would be golden.
Old Apr 17, 2017 | 08:19 PM
squarles67's Avatar
Yes the 400 direct piston will fit, at least it did in my 2004 4l80
Old Apr 17, 2017 | 08:23 PM
Game ova's Avatar
Thank you sir.
Old Apr 17, 2017 | 08:31 PM
squarles67's Avatar
With the 400 piston in there it had enough room for 6 clutch plates instead of 5 with the bonded piston
Old Apr 17, 2017 | 08:43 PM
Game ova's Avatar
Trying to decide if Im going that route or not. I've seen it stated that a 5 clutch setup will carry the 400 into 4 digit power, and that the 6th clutch will just create extra drag. But at the same time, it's better to go ahead and future proof the tranny now than later. Did you use .77 steels?
Old Apr 17, 2017 | 08:50 PM
squarles67's Avatar
I actually ended up with the 400 drum and 36 element sprag in my 4l80E.
Without the waveplate the stock .080 steels fit in the 80E drum
Old Apr 17, 2017 | 09:10 PM
Game ova's Avatar
Why did you use the 400 drum instead?
Old Apr 18, 2017 | 06:04 PM
squarles67's Avatar
it's not the stock drum, it's an aftermarket drum with 36 element sprag.
