298mm compatability with 03 4l60e
Once my old stocker was taken out discover it doesn't match this new one. Now after some research I see I have a 300mm unit with a 12 oclock bolt hole. this other unit does NOT have a bolt hole on top and has a 298mm shaft. it also has the ID tag '2SHO' on top, but can not find anything to decode that.
q#1 - can this unit even be used in my truck?
q#2 - if yes, then how? Adapter/spacer? What is needed?
Thanks!
Utilizing the "LT" style 4L60 would take a new flexplate, and at least an LT style converter.
Really though, I am not sure if all of the electrical connectors are the same.
Keeping the LS style 4L60 in there is the easiest route.
And Re-drill the Flexplate for the 10.75" torque converter bolt pattern on the 298mm converter, RE-DRILL it! Do Not hack up your Flexplate by slotting the hole (I hate that!)
The 298mm trans you have is electrically compatible with your truck, 2SHO means it's from a 2002 S-10.
I always agree with Clinebarger because he is a pro and I learn from him.
We should always appreciate it when after working on transmissions all day he still has the time/energy and enthusiasm to answer transmission questions.
While the "2SHO" only means to me that it is a 2002 trans, the "PWM" on the pump indicates it is at least a 1996 and therefore electrically compatible with any LS1 PCM.
What I’m trying to figure out now is what 298mm converter to purchase, Is redrilling the spacer mandatory because there is no converter that will line up the same bolt holes?
And then a spacer is necessary I believe, will this spacer still allow everything to fit in the bell housing? And what spacer to I track down?
thank you!!!!
thank you!!!!
The 298 mm I think lacked an extra clutch plate somewhere and had a bit weaker torque converter clutch or something like that. And they were a bit shorter overall, which may or may not be an issue.
