Powerglide vs TH400
I am upgrading either to a 454ci lsx or a 427ci ls7 block. Car should be making around 600whp. Also dropping the weight to 2700lbs and no more street driving. I was on index 10.5 class and now i wanna do index 9.50
I have been told the local built 4l60e won't be able to survive and cost of getting a built one through RPM transmission level 7/10 is over $4k. Even RPM transmission told that if i decide to upgrade in future, it will not hold power over 750-800whp reliably. I want a transmission to hold 800whp reliably in case i decide to upgrade the engine or spray the motor.
Therefore i decided to go with TH400, however, FTI suggested the powerglide instead. I told them i want a tranny to hold 1000hp so that might be the reason they suggested the glide, but im really not gonna make that much right now. They told me with a proper efficient converter and gearing the powerglide should run better than a turbo 400. Cost is $600 more then a th400 for 1100hp rated PG. Really can't decide which one will work best.
Anyone who tried both or have similar setups/transmission, please let me know.
i also think the price difference only reflects a powerglide with stock gearing. if it were my car id go th400, which is why i went 4l80e cause I wanted to keep the overdrive, you can also get a th400 down to 140lb if weight is a concern over glide. and you have the 2.48 1st gear to get you off the line
Powerglide level 4 is $3295 and rated 1100hp with aftermaket gears
I believe the Sprag is the weakest point in the turbo 400. Then the input shaft and fw hub. FTI also includes aluminum direct drum which saves 5 pounds.
I'm sure there must be a reason they recommended a glide. Let me know if you have any experience with similar combos.
