Engine transmission compatibility
Old May 20, 2017 | 03:23 PM
Angel Bryce Comstock's Avatar
Default Engine transmission compatibility
Hey guys kinda new to the whole LS thing, I'm putting together a drive train and I need to know if it will work. I have a 2001 5.3 vortec with a flashed ecu, and a 4l60e tranni. But the tranni is from a 94 ss impala, so my question is will the 2001 ecu run the 94 transmission?
Old May 21, 2017 | 06:47 AM
Old Geezer's Avatar
There's a forum for this kind of ???
Old May 21, 2017 | 07:58 PM
clinebarger's Avatar
So my question is will the 2001 ecu run the 94 transmission?
Not without a Valve Body, Plate, & Harness swap from a 1996 & up transmission.
The converter clutch material in a original '94 converter is not compatible with PWM TCC strategy.....Have the PWM turned off in the tune!
