Rubber plug in transmission pan
Old May 21, 2017 | 01:32 PM
Reaper_SS's Avatar
Default Rubber plug in transmission pan
So I went to a junk yard 2 weeks ago to find a truck pan. I got one but noticed it had a rubber plug in it. So I went back today and noticed every single one had a rubber plug in it. The only one that didn't was a shallow pan. I wanted to use the truck pan in hopes I would benefit from the extra fluid it holds.
my question is, would you use a trans pan with a rubber plug? I really want to try the truck pan but i don't wasn't more headaches in the process.
Old May 21, 2017 | 06:06 PM
SMaXMan121's Avatar
pictures
application
Old May 21, 2017 | 06:39 PM
01ssreda4's Avatar
They have drain plugs in them stock. Can get a new steel pan on ebay for about $30.....or spring for one of these....
Old May 21, 2017 | 07:01 PM
clinebarger's Avatar
No factory 4L60E pan had a rubber plug from the factory......
'98-'03 deep pans had a steel drain plug with a rubber gasket under the head.
Starting in '04 the drain plug was eliminated.
In '05, Gm put a "dip stick" stop in the pan & eliminated the valve body mounted stop.
If you don't care about the drain plug, GM 24240207 is super cheap at around $12.
Old May 21, 2017 | 07:20 PM
LLLosingit's Avatar
I wouldn't use it, I work at a salvage yard, The plug is put in the pan after they puncture it to drain the fluid. It's only meant to keep them from leaking and contaminating the environment after they are placed in the yard.
Old May 21, 2017 | 07:47 PM
Reaper_SS's Avatar
I saw this online as well. Oh well, $20 lesson.
Old May 22, 2017 | 04:48 PM
tfi racing's Avatar
Pull out the rubber plug,hammer the metal back into shape and weld it up,done plenty of them over the years.
Old May 23, 2017 | 07:45 PM
truckdoug's Avatar
my favorite is when the pierce the hole right next to the drain plug bolt
lol they dgaf
Old May 24, 2017 | 06:24 PM
LLLosingit's Avatar
lol they dgaf
They pierce them because it's quicker, Even if every trans pan had a plug like oil pans do they will still put a hole in it.
Old May 31, 2017 | 01:25 PM
Reaper_SS's Avatar
what filter would I get with that pan? Same as the 99 tahoe?
Old May 31, 2017 | 10:29 PM
Reaper_SS's Avatar
I guess I'm the only idiot that doesn't know. 99 tahoe filter doesn't fit in that pan. Another $20 lesson. So what filter goes with that pan?
Old Jun 1, 2017 | 07:34 AM
01ssreda4's Avatar
A car filter!!!!
Old Jun 1, 2017 | 07:53 AM
98CayenneT/A's Avatar
Get a filter for a 4l60e deep pan
http://m.oreillyauto.com/h5/r/oap/si...3230&ppt=C0023
This one right here
Old Jun 1, 2017 | 08:34 AM
Reaper_SS's Avatar
This one right here
that's the deep pan for after 03 right? That is shaped for the notch in the pan? I got the deep pan for pre 03 and it didn't fit.
Old Jun 1, 2017 | 08:57 AM
What didn't fit ?
Here is my pan.
Old Jun 1, 2017 | 09:56 AM
Reaper_SS's Avatar
What didn't fit ?
Here is my pan.
I meant the deep pan filter. I got the deep pan filter for pre 03 and it didn't fit in the pan because of the notch in the corner. I'm thinking the post 03 deep pan filter is shaped different because of that notch.
Old Jun 1, 2017 | 11:15 PM
I'm surprised the "Metal Bottom" GM 24208465 style filter is still produced, Leave it to the aftermarket to make an obsolete part
You need GM 24208576 filter kit,Comes with a OEM gasket.
Old Jun 2, 2017 | 09:09 AM
Docrocket1967's Avatar
Good ole rubber plug.....just so the salvage yards dont have to take the time to drain the trans the proper way
