Transmission problem? (loud screaming noise)
Old May 28, 2017 | 03:32 PM
Shi's Avatar
Shi
Default Transmission problem? (loud screaming noise)
Hey
I'm gonna loose my mind soon and drive my truck of a cliff if I dont figure this out. The noise in the clip comes after 5-10 min from a cold start. I have changed brake shoes, wheel bearings, i took out the diff and pinion today and the bearings looked good imo.
I have even changed the transmission (it had bad gears too) but it didn't help. Can it be something in the tune that makes it go bananas or what could it be?
it's a 4L70e
Please help!
Old May 28, 2017 | 05:51 PM
performabuilt's Avatar
LS1Tech Sponsor
Hard to say but seem to happen when diff is unloaded and disappear when its loaded strange sound but I have heard diff whine like that when pinion depth was wrong under decel.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old May 29, 2017 | 01:52 AM
07NBSChevy's Avatar
You sure its not one of your air pumps?
Old May 29, 2017 | 10:14 AM
Shi's Avatar
Shi
Im gonna change carrier and pinion bearings, i'll check the depth when Im putting it together again.
Yes, they are running fine.
