Transmission mount question
Old May 28, 2017 | 07:52 PM
BigGoom's Avatar
Default Transmission mount question
I did a LS swap on my 95 Bird. I bought a UMI torque arm relocation crossmember for a 4L60E. What trans mount are you guys using? It looks like the mount needs to be offset because where the mount mounts to the tailshaft, the stud on the mount needs to be farther back from the holes. I did not have the mount when we went to mock it up, but will a stock mount work or is there something special?
