mild rebuild - which 4l60e spacer
Hi all...undertaking a mild rebuild, i.e. new clutches/steels, bushings, seals, 'vette servo and a few Transgo valve body mod's (I'm going to post the full recipe on here in case I might be creating a mismatch of mod's or something!).
My question is which spacer plate should I install, in case the old one is damaged by the ***** or something? I plan on using Torlon *****.
Thanks for any direction!
jl
jl
Repair the plate with these.....http://www.ebay.com/itm/GM-700R4-4L6...-/262215527021
If you want to replace, Use this.....https://www.summitracing.com/parts/trg-46-plt-95
