1993 Trans Am Speedo off. Have correct gears.
My 1993 Trans Am with a 4L60 has 3.73 rear gears in it (took diff cover off, counted and confirmed), it has 275/40/17 rear tires (25.7 diameter), a 15 tooth drive gear installed, and the factory 44 tooth driven gear. From all my calculations it should be correct, but my speedometer still reads about 7mph too fast (reads 77mph, but going 70mph via gps). Not quite sure what else to look for so any advice would be appreciated!
It runs at 2400 rpm reading 70 mph on my gps, but the speedometer reads 7mph faster. When I had the rear diff cover off a few days ago I counted the teeth to make sure it had 3.73s, so I know that's correct. I swapped out the drive gear on the trans to a 15 tooth from the factory 17 tooth and I have the correct 44 tooth driven gear installed. According to every source I've referenced I should be good to go, but my speedo is still off. Definitely confusing.....
