Trans fault code help
Old Jun 25, 2017 | 04:39 PM
Jeff Payne's Avatar
Default Trans fault code help
Im getting a p1810 trans fluid pressure valve fault code. 4l60e in a LS1 swap. Trans shifts great, doesn't slip and is super smooth. What symptoms could I see if the trans fluid pressure valve was bad?
Old Jun 25, 2017 | 05:33 PM
98CayenneT/A's Avatar
You could try replacing you manifold pressure switch. If you drop your pan it is pretty easy to change.
It will be bolted to the bottom of the valve body. Here is a picture of the side you will see. Just undo harness, remove bolts, then reverse order.
