4L60E do you think this build will last?
Thanks for taking the time to read this! Info on ride 05 Tahoe 2WD 4.8 125k miles. My tranny just went out and I bought this as a replacement. In my mind if I bought a raced out high horse power 4L60E it wouldn't get as much ware of experience such harsh conditions, thus lasting me a long long time. Info on my driving, I do mostly highway to and from work, but I like to step on it while city driving and I do some off roading as well. Paid $1340 shipped from:
http://www.ebay.com/itm/4L65E-4L60E-...-/263052009021
The specs as followed......
RAYBESTOS Z PACK CLUTCHES AND NEW KOLENE STEELS
WIDE ALTO ENERGY BAND
BEAST HARDENED SHELL
VETTE SERVO
500 BOOST VALVE KIT
11 VANE PUMP KIT WITH HD ROTOR
NEW HD CONVERTOR (2000 STALL IF NEEDED)
B&M MATCHED WITH TRANSGO SHIFT KIT
Thanks for any input!
Z-Pack is a joke, A stock 6-clutch set-up is better.
WIDE ALTO ENERGY BAND, If a new Reverse Input Drum was used you will probably be OK, The stock Borg Warner Band is a very nice piece.
BEAST HARDENED SHELL, If the run-out was checked & it passed.....Good, If not....You would have been better off with a New Delco Shell.
VETTE SERVO, No problem with this.
500 BOOST VALVE KIT, If it's a Trans-Go Boost Valve.....I hope it was checked for being machined correctly.
11 VANE PUMP KIT WITH HD ROTOR, They come in 7, 10, & 13 Vane variations, A stock 13 Vane Rotor would be fine for the application.
B&M MATCHED WITH TRANSGO SHIFT KIT??.....What?
Also, there is no 11-vane pump. There are 10-vane and 13-vane pumps.
Also, there is no HD rotor - there are stock and very expensive billet rotors; doubt it uses the latter.
Sounds like a 10+ year old type rebuild; better parts are available, especially the many improvements made by Sonnax.
so I'm pretty much screwed
