almost 5 vs 8?
Old Jun 26, 2017 | 06:31 PM
blue09rocket's Avatar
Default almost 5 vs 8?
last year I drained and filled my trans fluid, almost 5 quarts came out, I always drain into a big plastic pan and then dump that into used oil containers to see how much trans fluid came out so I can replace the exact amount. ( I always check the level after though to verify) did it again this year (had to replace my trans gasket and dispstick tube seal) and now I got almost 8 quarts out. Don't know if it makes a difference or not, but last year my car sat for about 2 1/2 months, so far this year it has sat almost 6 months before I drained it.
Old Jun 26, 2017 | 06:34 PM
clinebarger's Avatar
Converter drain back, Normal condition.....The longer it sits, The more will drain out.
Old Jun 27, 2017 | 10:45 AM
mrvedit's Avatar
Moderator
The trans and converter together hold 12-13 quarts; some parts of the trans will drain very slowly into the pan. Your experience sounds typical.
